RuneB
Nørd log
Opvarmning
Løb 5 min
mave/ryg/liggende rotationer
Tom stang
Ol squat (paused og bounce)
Træk DL mobilitet
Træk balance
Træk fra hæng
tid: 20 min
Ol squat
5X85
3X75
3X75
3X75
3X75
3X75
3X75
3X75
3X75
p: på minuttet.
skal holde mig tilbage på hælene
som altid usymmetrisk set forfra pågrund af min benlængde forskel
En lille smule extension smerter, formentligt fordi jeg har båret rundt min på
datter hele weekenden. no worries
Et bens træning
Overhead lunge 30 kg
Overhead isometrisk lunge 30 kg
Step ups og lidt single leg squat fra box
Hanging leg raise
8 X 6, BW semi strakte ben
Dagens artikler:
Assistede jump training. "Research on Assisted Jump training suggests improvements in performance are seen as a result of increased of take off velocity"
http://www.elitetrack.com/blogs/details/4556/
"During fatigue, the authors found that the ankle and knee reduced their contribution, while the hip moments increased its participation. This study agrees with our observations, and those of our partners that are using the force plate technology. For example, Kansas Basketball, has found RATE to be reduced during periods of heavy training or competition. These observations occur because the RATE of force is predominantly achieved by the ankle and knee joints".
http://www.spartascience.blogspot.dk/2013/01/how-to-reduce-fatigue.html
LOL en idiot! Kom igen Eric Cressey
http://www.ericcressey.com/5-lose-fat-gain-muscle-get-strong-move-better-31
Her er hvordan man undgår at blive en bedre!
http://www.flotrack.org/coverage/249744-Workout-Wednesday-Season-7
Endnu mere BS.. stop nu Crossfit!
http://breakingmuscle.com/crossfit/it-s-crossfit-and-it-s-going-hurt
"Results of training studies comparing power and strength training show that the most effective training method is contingent on the relative strength of the athlete. For example, in a study using relatively weak athletes who had an average 1RM squat of 1.3 times body weight, 10 weeks of either power or heavy strength training produced similar power improvements. Neither method was found to be significantly better for increasing power because the athletes were relatively untrained and will therefore respond to a wide range of stimuli.
A second study compared the effect of power training in relatively strong athletes with an average 1RM squat of 1.9 times body weight and weak athletes with the average 1RM squat of 1.3 times body weight. Results showed that although both the strong and weak groups did the same power training, the stronger athletes had a much larger improvement in power output. "
http://www.charlespoliquin.com/ArticlesMultimedia/Articles/Article/966/Boost_Performance_by_Knowing_How_to_Boost_Power.aspx
Participants in the study were trained college-aged women with previous athletic experience. There was a control group that only performed two 100-meter sprint tests, with 9 minutes rest in between. A treatment group performed two 100-meter sprint tests with the first one acting as a baseline time. Then they performed one set of four of a 4RM half back squat, rested nine minutes and ran the 100-meter sprint. Performing the pre-activation squats resulted in significantly faster 100-meter times with the treatment group averaging .20 of a second faster than their baseline times. The control group had no change in performance between the two tests.
http://www.charlespoliquin.com/Blog/tabid/130/EntryId/876/Tip-254-Get-Faster-Increase-Sprint-Performance-with-A-Heavy-Complex-Warm-up.aspx
Edited by RuneB
Fedt!
Rune, kan du ikke give en broscience take-away for hver artikel/studie du linker til?
Og hvorfor er Cresseys non-eccentric pull for conditioning en dårlig ide? Hans pointe er vel god nok - minimer stress, når du laver conditioning på off-days...
landingen.. = stor eccentrics stress
God ide med broscience take away.. jeg har ikke læst original artiklerne på alle.. så tænker dem mere sominspiriation... tør ikke rigtigt konkludere noget. men jeg lettere røven og læser original artiklerne.
princippet er vel fint nok.. kunne være meget fint i nogen sammenhæng. Ved nogen coaches bruger deep<br />water jogging udfra samme tankegang.. Så nej ikke princippet men selv øvelsen.
Opvarmning
Løb 5 min
3 runder:
skrå folde knive 20
hyperextension (bent back) 20
rygliggende bensving 20
lateral squat 10
1 runde:
medball rotation kast, højre 20
medball rotation kast, venste 20
medball overhead throw 20
halvkneeling, rotation, højre 20
halvkneeling, rotation, venste 20
halvkneeling, extension 20
Vl opvarmning, tom stang
Front squat, paused
Front squat, drop
Clean dl mobilitet
Hang clean pull
Hang clean
Tid: 20 min
Press
20,30,40 opv sæt
5x45
5x45
5x45
p3
DB bench press
5x15 tempo: 41X0
10x20 tempo: 41X0
10x20 tempo: 41X0
10x20 tempo: 41X0
p1
Chin ups
5XBW
5XBW
3XBW
3XBW
p3
Pull down
12X35 tempo: 4120
10X45 tempo: 4120
10X35 tempo: 4120
10X35 tempo: 4120
p45s
Face pull, overhead
12X15
12X15
12X15
12X15
12X15
p15s
- En lidt underlig variant der rammer min bagskulder og tvinger mig til at fokuser på at holde nakken i ro
DB Biceps curls
12X9
12X9
12X9
5 min løb hjem
Edited by RuneB
D.8/02/2012 i Rebæk Søpark med Steven.
Vl opvarmning med tom stang.
BS (bounce og paused)
Træk hæng
Træk balance
SG DL mobilitet
Fuldt træk
Tid: 20 min.
Bænk press
5x70
5x70
5x70
p3
Chin up (bredt greb)
5
5
3
3
p3
Havde travlt så stoppede her
Edited by RuneB
11/02/2012 I Rebæk Søpark med Steven.
Opvarmning
En rodet omgang:
Agility drills, små hop og retnings skifte
Lidt VL træk og vend
mave øvelser
tid: 20 min.
Press
20,30,40
5X45
5X47,5
5X50
5X50
p3
Back Squat (BS)
20,40,60,80
5X90
5X90
5X90
p3
Chin ups (bredt greb)
5
5
5
p3
DB Biceps curls
10X10
10X10
10X10
10X10
10X10
Edited by RuneB
Træning med Pt kunde. Kl.13:00
Opvarmning:
10 min jog
Bensving
Koordination a 20m
Fodvip
Knæløft, et ben
Stigningsløb 3 x 80m
Sprint: acceleration
4 X 20m (min kunde kørt 8 stk, 100%) 90 % af maks.
Dejligt at sprint lidt igen. Længe siden.
Træning med Steven, Rebæk Søpark
Opvarmning:
Tom stang VL.
Back squat (paused og bounced)
Front squat (paused og bounced)
Front squat drop
Træk fra hæng
Tid: 20 min
Dødløft
60,80,90,100
5X100
god fart
VL teknik, 30 kg
Front Squat (fokus på at holde ryg og albuer)
Front squat drop (samme)
Træk fra hæng
Bænkpress
20,40,60,70,75
2X80
5X70
5X70
5X70
p3
Chin up (BW)
5
5
5
3
p3
Lateral raise
10X12
10X10
10X10
10X10
10X10
p1
Edited by RuneB
Træning Østerbro d.15/02/2013
Interval med PT kunde.
10x150 (tid: 35) + 4 * 150 (tid -30)
p40s + p45s
nemme interval får mig, Hastigheden passede med forfods løb, så har fået dejligt øm lægge
Træning med Steven, Rebæk Søpark d. 16/01/2013
Opvarmning, Tomg stang VL
Squat
Træk balance
Træk fra hæng
Træk
tid 15 min
Skulderpress
opv. 20,40,50,
1x52,5
2x5x52,5
1x4x52,5
p3
Back squat
opv. 20,40,60,80,90
2X1X95
2x5x95
1x95
p+3
RDL
opv. 60
4x8x80
p1
Chin up
5
5
8
p3
Edited by RuneB
ja.. der kommer ikke mange artikler. Beklager.
Har lidt travlt. Start nye kunder op, massage hold og arbejder på at finde en klinik også
Dagens træning.
Vl teknik træning i IK99 med Tim og Karina som træner
Opvarmning
3 runder
armstræk 20
V situps 20
rygstrækker 20
Duck walks 2 X 10 m
Overhead squat ca. 4 x 4 reps
VL Teknik:
Vend hop, strakt arm.
fokus: land samme sted, hold armene strakt
Frivend til Front squat
fokus: albuerne hurtigere på. Kom til at skifte Back squat ud Front squat, så jeg får mig vendet endnu mere til at have de albuer oppe.
Vend bold
fokus: ingen lyd, stang til kroppen/lige op, op på tå ikke hæl
kg, reps og sæt har jeg overhovedet ikke styr på. Næste gang bliver der skrevet ned under træningen
Back Squat
30,50,70
2x4x80
og da jeg kom hjem, efter shake
Chin ups
8
6
6
Er startede til VL så jeg kan lære at undervise i det. Virkelig lærerig træning idag. Ikke mindst sjovt
Edited by RuneB
Træning i Crossfit center, med Andreas
Opvarmning
Random cirquit:
Jog 5 min
5 X 10 armbøjninger
3 X 20 hypers
3 X 20 rygbøjninger
3 X 20 v-situps
3 X 10 glute ham situps
Medball
Stående rotation 2 X 10
Stående kuglestød 2 X 10
Halv kneeling rotation 2 X 10
Tid: 15 min
Vl teknik (tom stang)
Spring med stang midt lår 6 x 4
Frivend (FV) med stang midt lår 6 x 3
FV med stang midt lår + benbøj 6 X 2+2 reps
Vendbold 6 x 3 reps
Tid: ca. 1 time
Træk fat DL
20, 40, 50
5 X 4 X 70kg
Press
20, 40, 50
3 X 52,5
5 X 50
4 X 50
4 X 50
6 X 40
8 X 30
Chin ups
6
6
5
5
MEGET LANG TRÆNING
Edited by RuneB
Opvarmning
5 min jog
2,5 min 100/100 submaximal sprint/jog
Mave+ryg+armstræk 3 runder
Andegang 4 runder
Vægtløftning/træk i IK
Trækbalance 4-6 sæt x 4 reps
Trækbold 4-6 sæt x 3-4 reps
(råtræk) RT fra knæ 4-6 sæt x 3 reps
- vi rundede omkring 35 kg som maks
Ben bagpå
30,50
8X70
6X85
2X100
4X100
Ben foran, tempo 1310
4X6X50
Edited by RuneB
Opvarmning
Mini cirquit: 3 runder af 20
Lunge
Air squat
V situps
Rar (træk fat stiv benet dødløft)
tid: ?
Bænkpres
20, 40, 60, 70
3 X 5 X 75
3 X 3 X 60 ( 3 sek pause på brystet)
Chin ups
6
6
5
3
Db press
10
2x8x17,5
2x8x12,5
Face pulls
Curls
12x10
8 x 12,5
10 x 10
Edited by RuneB
Med Steven i IK
Opvarmning:
Lunge
Air squat
V situps (med benløft rør hæle)
hyper extension
- stille og roligt
Trækbalance 6 sæt x 4 reps
Trækbold 6 sæt x 3-4 reps
(råtræk) RT fra knæ 6 sæt x 3 reps
- rundede omkring 30 kg på sidst 2 sæt i være øvelse
- trækbold føltes godt idag
Træk fat DL
Blev rodet og dårlig teknisk
prøvede med 2 reps fra klods, endt på gulvet og rodet rundt i 1ener og frustrationer over teknik
ca.5 X 70-80 kg
ss
box jumps 5X3XBW
Edited by RuneB
Træning i IK 99
Opvarmning:
Andegang 4 runder
Trækbenbøjninger 4 runder
Vægtløftning/Stød
FV + Benbøj 9 sæt x 2+2 reps (op til 50kg)
Pushpres fra split 6 sæt x 4 reps
OP fra split 4 sæt x 4 reps
BS
20,40,60,80,90
4,5,5 X 100
Edited by RuneB
Træning i Rebæk
Opvarmning
Mini cirquit. 3 runder af
Lunges
Air squat
Statisk hyper
Hoftebøjninger
Strakt ben træk fat DL
Statisk 1 bens glute bridge
- lidt rodet da jeg måtte stop og tilbage igen og variered øvelser lidt og legede lidt rundt. anyways fik nogen gode ideer
Bænkpress
5X75
2X75.. med pause på bryst.. synes ikke den kørt så stoppede sættet. var ikke rigtigt varm nok
VL
FV + ben foran 8 X 2 + 2 (optil 40 kg)
Pushpress fra split 4 X 3 (træt så stoppede)
Skulderpress
3 X 5 X 50kg
Chin ups
8,8,6
Strict pull down
4 X 12 X 6 stacks
VL med Tim IK 99
Opvarmning
10 min jog
duck walk 4 runder
VL teknik
Clean + Push press fra split 8 X 1+ 2 reps (op til 40 kg)
Stød 4 X 1 + 2 reps (op til 30 kg)
Træk hiv/træk hiv til knæ ? X 2 + 2 reps (op til 80 kg)
sæt er ca.
Back Squat
20,40,60,80,90,100
2 X 5 X 90
Mini cirquit
6 X 6 hanging leg raises
4 X 10m walking lunge
Edited by RuneB
Træning IK 99 med Steven
Opvarmning
noget halv rodet:
squat
lunge/lungestræk
v-situps
strakt bens træk fat DL
bent back straight leg DL
duck walks 4 runder
VL teknik
Træk Balance
Vend fra hæng + ben foran
Vend fra boks lige over knæ + ben foran (op til 60kg)
Stem fra split stående (op til 40kg)
Stød (op til 40kg)
BS (teknik)
20,40,60,80
2 X 2 X 90
DL (teknik)
40,80
14 X 1 X 100 kg
1 X 1 X 110
2 X 1 X 120
2 X 1 X 130
lang opvarmning, langt og meget snaksaligt teknik pas. Meget lang træning. Men hyggeligt.
Edited by RuneB
Vl i Ik 99
Opvarmning
10 min jog
3 runder a 20: mave, ryg, armbøjninger
4 runder andegang
Vl teknik
Træk Balance
Træk fra knæ, med stop (op til 40kg)
Træk fra gulv (op til 40kg)
Front squat
4 X 40
6 x 50
4 x 70
2 x 90
6 x 50
4 x 70
2 x 90
6 x 60
Fremliggende leg Curl
3x10x15 (dorsal flekteret ankel)
10x10 (plantar flekteret)
Edited by RuneB
